making part
making part
making part
Hi
I used Emboss, Extrusion-1 & Revolution-3 to create a Lourve type shape in rim. Is there a more ideal way to create the Lourve Type Shape?
Please see 2015 ffile attached
Regards
CB
Curtis_Waguespack
Hi C_Burton,
See the attached file, the only thing I did differently was use the Shell feature to remove the bottom of the louver, thus eliminating an extrude and pattern feature.
I hope this helps.
Curtis
JDMather
@Anonymous wrote:
Hi
CB
If you edit the Shell feature - not sure you really need these Extrusion features (see attached file).
Have you installed the lastest Service Pack and Updates for 2015?
Edit: Yes what Curtis said.  Smiley Wink
Thanks to you both
