Making it pretty to work with - Autodesk Inventor
MatsNorway1
Message 1 of 9
MatsNorway1
Any way to refine appearance by default? Any settings In Inventor that makes this a bit more pleasant to the eye to work with? Making the edge line thinner etc. Anti aliasing.
‌:nauseated_face: ‌:face_with_medical_mask: Fusion 360
Replies (8)
Message 2 of 9
CCarreiras
HI!
Go to tools -> Aplication Options:
You can tweak some settings and create a file with all definitions to import in another pc, or when you install other versions.
CCarreiras
Message 3 of 9
blandb
You could try using "Shaded" vs. Shaded with edges. Does that help you?
Autodesk Certified Professional
Message 4 of 9
johnsonshiue
Hi! Or Realistic with Ray Tracing (GPU accelerated).
Many thanks!
Software Test Engineer
Message 5 of 9
MatsNorway1
No improvements yet. Ray traced renders is not an option for this 😄 But we use Ray traced renders a lot for previews and customers.
Message 6 of 9
Ivan_Sinicyn
don't forget reboot Inventor
INV 2025.3
Message 7 of 9
MatsNorway1
Edit: not sure if that was an improvement. It is as if sharpness was turned on and now it is messing with the clarity. Its blurry now. What is needed is Anti Aliasing and shaded lineweight adjustability.
Message 8 of 9
Ivan_Sinicyn
You can force antialiasing in the video card driver settings
INV 2025.3
Message 9 of 9
MatsNorway1
Did that. Its sufficient/best i can get for now.
