Hello every one,
what I need to do are to create a grease hose in my assembly ...
when I try with TUBE AND PIRE RUN the minimum size that i can go is 1/4" I need a hose with 1/8"
Can you help me ?
Solved by blair. Go to Solution.
The Min/Max hose sizes are controlled by the Family Table Properties for your CC library. The attached PDF file should help.
