MAKING A HOLE ON CURVED SURFACE
baliasM74U3
baliasM74U3
Hi Experts
INV 2018
What is the best approach in inventor to make a hole on a curved surface ?
The process of making this part will be like, I will laser cut a part with the hole and roll it to required radius.
I could have used the unfold refold option for a folded part, but here the part will be rolled .
Any thoughts ?
gcoombridge
In the sheet metal environment use cut and check the cut normal box. This will give you perpendicular edges. Unfold/refold will work but is less robust and you can't use existing sketches
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
SBix26
Another possibility, one which I don't normally recommend, is to create the holes in the flat piece before it is rolled.  See the attached file (2018 format).
Sam B
Inventor Pro 2021.2.1 | Windows 10 Home 2004
LinkedIn
johnsonshiue
Hi! There might be multiple ways to get the desirable holes. For example, you could Thicken -> Intersect from outside and then inside. Please share the example file here. Forum experts can help take a further look.
Many thanks!
Software Test Engineer
