Make Individual Part files from a Multi-Body Part File
I have a master part file containing 6 indiviual solid bodies. I want to make an individual part file for each one but when I'm in the "Make Components" command it will only select 3 of the 6 files. Why is this?
Please see attached part file with the 6 solid bodies.
Thanks in advance!
rdyson
I have no idea but Make Part works. You'll just have to repeat it for each part
PDSU 2016
rhasell
Hi
I had a look, and it is related to your "Master" View rep.
The three solid bodies in question have their visibility turned off.
If you switch the visibility back on, the 'Make Components' works.
Reg
2026.1
Awesome, Thanks!
