Make Components dialog greyed out when adding to existing assembly
Sim-event
Message 1 of 12
Sim-event
Hi, hoping someone can advise a solution or point me in the right direction.
Recently migrated to 2022 from 2021, and everything has been fine up until now.
I have successfully created assembly from multibody part using the "make components" route.
I now find myself needing to add a few more parts to the assembly, in previous releases i simply go back to "make components" choose the existing assembly and away we go, in 2022 all options now grey out as soon as i pick existing assembly and there is now no way to proceed.
Any help much appreciated as i'm in the middle of a time sensitive project and can't roll back to previous release now as the file isn't backwards compatible
Kind Regards
Simon
Replies (11)
Message 2 of 12
JDMather
@Sim-event wrote:
Any help much appreciated as i'm in the middle of a time sensitive project .....
Make Part instead and then add it to the assembly.
Place Grounded at Origin.
Message 3 of 12
Sim-event
Thanks john for the work around, unfortunately due to our workflow that is quite time consuming with multiple parts to add and if i create a new assembly i end up with lots of sub assemblies which our workflow doesn't lend itself to working with do to some of the upstream woodwork plug ins.
Does anyone know if there is a solution to fix the problem? is it something in my settings? or is it a bug?
Kind regards
Simon
Message 4 of 12
Sim-event
Kind regards
Simon
Message 5 of 12
Gabriel_Watson
This is a known issue (INVGEN-57952) of 2022.2 update. If this is something you really need working, uninstall this latest update and roll back to 2022.1:
https://forums.autodesk.com/t5/inventor-forum/2022-2-make-components-selection-dialog-not-working/m-...
Message 6 of 12
sundars
Hi @Sim-event
Thanks for reporting this. This is a known issue and we are actively working on fixing it. We apologize for the inconvenience. Please refer to INVGEN-57979 when discussing this issue.
-shiva
Shiva Sundaram
Inventor Development
Message 7 of 12
Sim-event
Thanks all for the input, looking forwarded to the fix as i only only installed update to fix sporadic crashing in sketches.
At least i now know its not only me 🙂
Kind Regards
Simon
Message 8 of 12
johnmondro4888
INVGEN-57979 experiencing the same issue here. Build 287, Release: 2022.2. Looking forward to a fix very soon. This is a HUGE time waster on large top-down .IPT > .IAMs. Thanks!
Message 9 of 12
Sim-event
HI,
following on from the comment of rolling back, could someone point me in the direction of the 1.1 update installert as its seems to have been unhelpfully removed from any of the update download locations. currently had to roll back to initial release which is now causing more problems.
thanking in advance
simon
Message 10 of 12
admaiora
Thanks.
I haven't updated yet.
Please fix this asap, quite critical for sono many users!
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 11 of 12
BDCollett
Still broken and the workflow for "Make Components" has changed when combining or splitting bodies.
Message 12 of 12
Sim-event
hi, @BDCollett,
Yes struggling with that change of workflow myself, raised a forum post myself, but got no traction,
https://forums.autodesk.com/t5/inventor-forum/behavioral-change-between-multi-body-parts-and-derived...
Have escalated with my reseller and had a phone call from Autodesk yesterday, to run through what has changed, so hopefully they might revert it back soon.
Regards the Make Components problem, I believe the problem is solved and a fix is due out soon
Cheers
Sim
