make an image see through in a sketch
berry.lejeune
berry.lejeune
Hi everyone,
Sometimes we get a design from a customer for a headstone of a grave.
Then I make a screenshot and put this image in my sketch. But how do I make the image see through or that the sketch line lay on top of the image and not underneath it
berry.lejeune
Found it. In the properties of the image, selecting "not transparent" solved the issue
SharkDesign
What happens if you offset a plane behind the sketch plane and put the image on that?
  Inventor Certified Professional
BDCollett
Bumping this. I don't recall this being default. It seems that construction lines are visible only.
I never needed to change the image properties in the past to see sketch lines through the image.
Then once you select 'Not Transparent' you cannot un-select it.
This feels like a bug?
rui_wang
Thanks for your reporting and information, @berry.lejeune
Tracked the issue on our internal system, INVGEN-85492. Thanks.
