I often use a project geometry from a part I have, and create a sketch and an extrusion from the sketch and make a new body. Now I take this second solid body and I use "make part" so that it becomes a self standing part. How can I then play with this new part and modify the sketch and add things (holes, anything) to it? In the new ipt file I created I cannot see the sketch, whether I break the link or I don't does not matter.
Essentially what I would like to do is to use a part A.ipt I have to "help me" create a sketch (by project geometry), extrude this sketch and make a new solid but then save this as a new B.ipt part and use it as an independent thing, modify it etc. and delete the solid body in the original A.ipt file and have no connection whatsoever between the two anymore. I guess it is certainly possible but how?
已解决! 转到解答。
