Macro inventor
Macro inventor
Macro inventor
I know it's possible to create scripts with Inventor and I looked up a lot of information, but I can't find a good tutorial on how to make what I want.
I want to make an macro that can be used in the following way:
I want to use 'copy object' to copy surfaces which I can select. Then I want to rename the created surfaceBody and then I want to export all the created surfaceBodies to an obj file.
Is this possible and how is it done?
Thanks for your help in advance.
Sander
Mark.Lancaster
@Anonymous
You may want to re-post your requirements over in the Inventor Customization Forum.  I will also tag @Curtis_Waguespack since he is a programming wizard.  Smiley Wink   He may have some code already that could help..
Mark Lancaster
Curtis_Waguespack
Hi sander.vermeeren,
I don't have anything on hand, and didn't dig too deep , but did find this to get you started:
http://forums.autodesk.com/t5/inventor-customization/associative-body-copy-api-sample-problem/m-p/44...
I hope this helps.
Curtis
@Curtis_Waguespack
@Mark.Lancaster
Thank you for responding,
I have placed it in the customization forum. Maybe some better explanation of my question. I don't want to just copy the surfaceBody.
Small example: If I create a pipe, then I want to use the feature 'Copy Object' and copy both ends of the pipe excluded the pipe's 'wall'.
Doing that I created a surfaceBody called srf1 as shown in the extension.
Then I want toe export that surfaceBody so not the solidBody.
I'm really losing a lot of time of figuring it out in the macro.
Sander
