Inventor Forum
Macro for saving drawing as PDF and DXF
3 REPLIES 3
JoãoASilva
3616 Views, 3 Replies
Hi!
Where I work, some files need to be sent to the supplier as PDF and DXF for production, and everytime I make something, I need to Save As PDF, then wait for it to save, then hit Save As again and choose DXF.
Is there a way to do this in a easier way?
Macros are welcome, of course!
João Silva
Mechanical Engineer
If what I said solved your problem, or answered your question, please use the ACCEPT AS SOLUTION or KUDOS buttons.
Or if it helped you, please hit "LIKE"
Inventor Professional 2023.3, Build 359
3 REPLIES 3
mdavis22569
in reply to: JoãoASilva
Why not just use iLogic?
Mike Davis
Lewis.Young
Here is some code containing two subs, one for PDF and one for DXF.  At the end of each sub you'll have to change the file path for saving the new documents. You can also add custom buttons to your ribbon that'll launch these macros.
SyntaxEditor Code Snippet
Public Sub PublishDXF()
    ' Get the DXF translator Add-In.
    Dim DXFAddIn As TranslatorAddIn
    Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        Dim strIniFile As String
        strIniFile = "C:\tempDXFOut.ini"
        ' Create the name-value that specifies the ini file to use.
        oOptions.Value("Export_Acad_IniFile") = strIniFile
    End If
    'Set the destination file name
    oDataMedium.FileName = "C:\$WorkingFolder\Engineering Data\testDXF.dxf"
    'Publish document.
    Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Public Sub PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 1
        'oOptions.Value("Custom_End_Sheet") = 4
    End If
    oDataMedium.FileName = "C:\$WorkingFolder\Engineering Data\testPDF.pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
This will work, however you may find an easier way through iLogic, as Michael mentioned
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
JoãoASilva
in reply to: mdavis22569
I did some investigation regarding iLogic rules, and i found what I wanted.
Thanks 😉
João Silva
Mechanical Engineer
