Machining operations do not display on drawing when a weldment is a subassembly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created a simple welded tube assembly with machined features in it. The tube was used in a higher level assembly with no issues, but when I illustrate the higher level assembly on a drawing, the machined features of the lower level disappear!
The model state of the view is set to "Machining" (also tried Assembly, Welds, and Preparation to no success) and the component view representation is set to "Default" (also tried Master.)
When the view is refreshing or updating, the features are evident, but when fully refreshed and no longer in a raster state, they disappear. In the pictures below you will see windows at the top of the tube and a circular notch at the bottom, that go away when the drawing is fully refreshed.
refreshing - note the green brackets
completed
