Low quality of icons in Inventor 2023
apbttu
apbttu
I installed Inventor 2023 and icons in menus are of very low quality and pixelated. If I select Override high DPI scaling in Inventor.exe properties, then icons look normal, but drawings become blurred and other problems appear. How to make the whole program to look normally? Display resolution is 1920x1080.Inv1.pngInv2.png
CCarreiras
Hi!
Try "Reset Inventor Utility".
Update windows and update graphic card drivers.
What is your graphics card?
CCarreiras
apbttu
Tried to use Reset Inventor utility and installed updates, but the result is the same.
Graphic card is Intel Iris Xe
johnsonshiue
Hi! What about checking both boxes in the DPI setting dialog?
Many thanks!
Software Test Engineer
apbttu
Seems that I found a solution
 If the boxes are selected as shown in the image, all works correctly.
Thank you for prompting
