Looking for some model / design challenges?
chris
Advisor Advisor
Message 1 of 13
chris
Okay, here is what I am looking for, I head a small design team of 5 designers/drafters. I'm trying to do some motivational stuff to get the others more engaged in their work and to start thinking outside of the box. I was just wondering if you guys had any specific designs or parts that you've modeled that require a little thought or have "tricky" geometry that, if not carefully considered, would produce a "wrong" result.
My goal is to offer up some sort of challenge within the team, give them a week or so in their spare time or at lunches to work on it and to then offer a Amazon or iTunes gift card to the winner ($50.00).The team is just learning about iParts and iLogic, and it's a structural design team, so they are use to structural members weldments... (don't know if that information helps determine a good challenge part or weldment). I have a couple ideas already, but I was just looking for something outside of my norm.
Accepted solutions (4)
Replies (12)
Message 2 of 13
S_May
Message 3 of 13
chris
Okay, thanks, I will look at those...
edit: the second link has a lot of good example... Thanks!!
 it's not so much a "modeling challenge" as much as it is a "process challenge. We are in beginnings of really changing "how" we model our parts / assemblies to be more future proof and less "dumb geo."
I've been challenging the team to consider when applying dim's and features to think of how this part or feature might be used by someone else for a different purpose or even next year.
Example, I did a contract at a company here in Houston where all I did for 1.5 yrs was set up Content Center parts. Thins such as complete iPart families of Swagelok connectors, Parker Fittings, etc. iLogic driven weldments, Excel driven weldments, all sorts of stuff. One thing we encountered was that is a piping spool required a welded elbow (45 or 90), to start with, but then also would require that elbow to be modified to a custom angle prior to welded that we had that "library" part, without having to do any "post weldment features" to correct the angle.
So I set up my own family of welded elbows (LR, SR) Tee's, Crosses, Reducers, etc that had variation built in... such as placing a 45 but then being able to "choose" what angle between 1 deg and 45 deg the elbow would be, and similar for the 90 but going between 46 and 90... stuff like that.
I'm really trying to get these guys to think about "tomorrow" instead of just modeling dumb geometry. Linking parameters instead of adaptability, iLogic driven "template parts" instead of copy save as, things like that.
Hopefully the incentive of a gift card and/or lunch will urge them to participate...?
Message 4 of 13
dgorsman
Trebuchets are always popular.  Smiley Happy
If you want something more related to hands-on teamwork get your hands on some classic Meccano (that's probably closest to structural work) or similar kits.  First couple of challenges would be to get the basic pieces in, then later creating virtual projects from those pieces.  Then do a team build on a randomly selected design.
Message 5 of 13
S_May
Hi @chris,
every pdf a challenge, if they do all, then they are king in the forum.... Smiley Happy
2018-03-21 19_41_28-C__CAD_Autodesk Inventor_Inventor Modelle und Baugruppen_INVG Übungen_IVNGWC-Cha.png
Message 6 of 13
TheCADWhisperer
Message 7 of 13
PaulMunford
Lots of good ideas on process here:
http://learnrms.com
And more examples here:
https://pin.it/jwmhqfchrd6ynj
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Message 8 of 13
Frederick_Law
You may need to look into your work flow and usual design for your customers.  There is not much benefit to get designer to use surfacing tools if they're not needed in produce design.
Look in old projects or current projects and see if your team can find way to improve design, file management, work flow etc.
Check new features in Inventor and see if they can help and use in your work flow.
Structural design can use frame generator, weldment and bolt connection.  Look into workflow: weld -> machine, machine -> weld -> machine, laser cut -> weld, laser cut -> machine -> weld -> machine etc and how to model with step by step assemblies to reflect each stage in production.
Get the team to point out things they want to change, optimize and let them come up with solution and vote for solution they want to use.
Even things like template, title block, dimension styles, material library etc.
Make every challenge an improvement for the team and add value to the company.
Message 9 of 13
TheCADWhisperer
@Frederick_Lawwrote:
.... not much benefit to get designer to use surfacing tools....
Surfacing tools can significantly simplify structural design.
Tip: Every example I have posted in this thread benefits from surface modeling techniques.
Message 10 of 13
Frederick_Law
Not the kind of surface I was thinking but you're correct.
Message 11 of 13
kelly.young
Autodesk Support
Autodesk Support
@chris here are a bunch of examples that might be interesting.
Finished GrabCAD Challenges
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 12 of 13
Hey do you have the inventor 3D file so I can download it? Want to know what it looks like in full 3d.
Message 13 of 13
TheCADWhisperer
Attach the *.ipt file of your attempt to model the geometry here.
