This is not what you want but it also may help..
http://inventortrenches.blogspot.com/2011/04/using-excel-and-ilogic-to-retrieve-part.html
I don't see where you define or assign Front_Shell, what makes it find different part numbers Front_Shell it a parameter not a value so how does inventor know it is a different size and find in excel? The parameter does not change so what defines the look up in the excel?
Front_Shell is the name of the parameter it does not change I think you need to have the value to be able to look it up in the spreadsheet. Not sure I just link you there.
I will go look at it and see But I am learning ilogic myself so not sure how much help I would be...
But you are asking it to look up the value of the Front_Shell but I think your code has it looking at the named parameter not the value. But let me look at the blog and see..
Hi jletcher and gordon.rogers,
Here's a quick example that might help.
Where C:\Temp\Test Part Number.xlsx looks like this:
You can use a rule such as this. Here I've added an array list to select from but that information will come from your size parameter in the real world. The size is then used to set the part number iproperty based off of the corresponding cell value.
'define the XLS to look at
myXLS = "C:\Temp\Test Part Number.xlsx" GoExcel.Open(myXLS, "Sheet1")
'set the list of sizes to choose from Dim myArrayList As New ArrayList i = 1 Do until i = 10+1 myArrayList.add(i) i = i + 1 Loop
'present the list to the user mySize= InputListBox("Select a size", myArrayList, "", "iLogic", "Sizes") 'find the row myRow = GoExcel.FindRow(myXLS, "Sheet1", "Size", "=",mySize)
'find the cell myCell = GoExcel.CellValue(myXLS, "Sheet1", "B" & myRow)
'set the part number iProperties.Value("Project", "Part Number") = myCell
'present the result MessageBox.Show("The Part Number is: " & iProperties.Value("Project", "Part Number"), "iLogic")
I hope this helps.
Curtis
Hi gordon.rogers,
Here's an example that will deal with the blank rows. Also this version builds the arraylist from the XLS file each time (rather than building the list internally in the iLogic code).
I hope this helps.
Curtis
'define the XLS to look at myXLS = "U:\iLogic examples\Shells.xls" GoExcel.Open(myXLS, "Sheet1") 'set the list of sizes reading from the XLS file Dim myArrayList As New ArrayList i = GoExcel.FindRowStart Do until i = 22 + GoExcel.FindRowStart ' 22 rows plus the start row position myArrayList.add(GoExcel.CellValue(myXLS, "Sheet1", "C" & i)) i = i + 1 Loop 'present the list to the user mySize= InputListBox("Select a size", myArrayList, "", "iLogic", "Available sizes") 'find the row 'looks for a row in the "Sizes" column that has a value greater than zero (blank cells return -1) 'and looks for a row in the "Sizes" column equal to mySize myRow = GoExcel.FindRow(myXLS, "Sheet1", "Sizes", ">" ,0, "Sizes", "=",mySize) 'find the cell value myCell = GoExcel.CellValue(myXLS, "Sheet1", "A" & myRow) 'set the part number iProperties.Value("Project", "Part Number") = myCell 'present the result MessageBox.Show("The Part Number is: " & iProperties.Value("Project", "Part Number"), "iLogic")
