Looking for an iLogic rule/code to add custom properties to parts in an assembly
Message 1 of 8
I am trying to run an iLogic rule (while in the assembly) to automatically go through all the parts as well as sub-assembly parts in the assembly to add the custom iproperties:
Job Name: xxxx
Job No.: xxxx
Release No.: xxxx
Extrusion Number/Description: xxxx
Finish: xxxx
I have seen some codes similar but I cannot figure out how to have these custom iproperties added. Could anyone be of any help? Thanks!
Also, in an .idw, when I add a parts list that references a general assembly of another assembly placed 10 times, for example, when I add the quantity it only has the quantity of one instance of the assembly instead of the quantity x10. The subassemblies give the correct quantity, but the parts just give the part length x10. What could be going on there? Thanks in advanced!
Replies (7)
Message 2 of 8
mdavis22569
Do you at least have them in the IPT/IAM template in the Iproperties/Custom?
Even if they are blank, but still there? Then you won't have to run the rule all the time.
Job Name: xxxx
Job No.: xxxx
Release No.: xxxx
Finish: xxxx
Mike Davis
Message 3 of 8
Thanks for the reply. I do now, but I didn't for this specific assembly and there are a ton of parts to add
Message 4 of 8
mdavis22569
Lets see what else we can do to help you with this ...
You know you can add things via Windows Explorer ...  this is just one of a few examples
Mike Davis
Message 5 of 8
Wow, will that add the custom iproperties to all those files at once!?
Message 6 of 8
mcgyvr
You can also copy iproperties from one file to many others using Design Assistant..
http://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/201...
But if you need to do this quite often then an ilogic tool to pop up a form asking for the information then looping through all the parts should be pretty easy for someone with ilogic skills (I haven't sat down and learned it well enough to help)
Here is the only code I have..
It prompts for a few standard and custom iproperties via a message box then fills out the information..
But it only does it for the current open file..
I would think someone could make it work and loop through all open documents or something like that..
pDescription = InputBox("Enter value for 'Description'", "Description",iProperties.Value("Project", "Description"))
If pDescription = Nothing Then Exit Sub
iProperties.Value("Project", "Description") = pDescription
pRev = InputBox("Enter value for 'Revision'", "Revision",iProperties.Value("Project", "Revision Number"))
If pRev = Nothing Then Exit Sub
iProperties.Value("Project", "Revision Number") = pRev
'Requires a custom iProperty called "MATERIAL"
Dim CustMatl As New ArrayList
CustMatl.Add("Custom Material 1")
CustMatl.Add("Custom Material 2")
Try
'attempts to set the value.. If custom field not found it errors out, creates the property and tries again
iProperties.Value("Custom", "MATERIAL") = InputListBox("MATERIAL", CustMatl, iProperties.Value("Custom", "MATERIAL"), Title := "Material", ListName := "Material")
Catch
' Assume error means the property was not found
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'create the custom property
oCustomPropertySet.Add("", "MATERIAL")
'set the custom property value
End Try
'Requires a custom iProperty called FINISH
Dim CustFinish As New ArrayList
CustFinish.Add("Custom Finish 1")
CustFinish.Add("Custom Finish 2")
Try
iProperties.Value("Custom", "FINISH") = InputListBox("FINISH", CustFinish, iProperties.Value("Custom", "FINISH"), Title := "Finish", ListName := "Finish")
Catch
oCustomPropertySet.Add("", "FINISH")
End Try
'Requires a custom iProperty called FINISH PRETREATMENT
Dim FinishPretreatment As New ArrayList
FinishPretreatment.Add("Custom Pretreatment 1")
FinishPretreatment.Add("Custom Pretreatment 2")
Try
iProperties.Value("Custom", "FINISH PRETREATMENT") = InputListBox("FINISH PRETREATMENT", FinishPretreatment, iProperties.Value("Custom", "FINISH PRETREATMENT"), Title := "Finish Pretreatment", ListName := "Finish Pretreatment")
Catch
oCustomPropertySet.Add("", "FINISH PRETREATMENT")
End Try
'Requires a custom iProperty called ROHS
Dim Rohs As New ArrayList
Rohs.Add("(6/6) FINAL PRODUCT SHALL BE ROHS 6/6 COMPLIANT PER EU DIRECTIVE 2002/95/EC")
Rohs.Add("(5/6) FINAL PRODUCT SHALL BE ROHS 5/6 COMPLIANT (LEAD EXEMPT) PER EU DIRECTIVE 2002/95/EC")
Try
iProperties.Value("Custom", "ROHS") = InputListBox("ROHS", Rohs, iProperties.Value("Custom", "ROHS"), Title := "ROHS", ListName := "ROHS")
Catch
oCustomPropertySet.Add("", "ROHS")
End Try
iLogicVb.UpdateWhenDone = True
Message 7 of 8
mdavis22569
Yes ...
Mike Davis
Message 8 of 8
mdavis22569
@mcgyvr  Option is good too..
There are probably a few other ways ....
Mike Davis
