Lofting?
Lofting?
gearjuice
Message 1 of 9
Lofting?
gearjuice
Hi I've been going crazy over loft for a day and a half.  I would like to confirm my suspicion.
Whenever I try to do a 3 curve loft of more inventor really doesn't like it.
But when I loft one part, then use the bottom curves from the loft to the next curve it works perfect?
Is this the way I should be working?  In rhino I just do huge chains of curves in lofts and it doesn't mind.
Is there a way to flip the UV of a curve it seems that what inventor is getting confused with...
Thanks!
Replies (8)
Message 2 of 9
JDMather
Attach your *.ipt file here so that one of the experts here can diagnose the issue of why it is failing.
Message 3 of 9
johnsonshiue
Hi! To change the UV in Loft, I guess you will need to change the section profiles or the section rails (vice versa). For this particular case, I personally would not use Loft. The foil portion can be done using a simple Sweep or Extrude (tapered). Then add a large radius fillet at the bottom.
Many thanks!
Software Test Engineer
Message 4 of 9
gearjuice
Hey JD here's the part.
If you try to loft all start/guide2/guide3 sketches gives weird results.
Thanks!!!
Message 5 of 9
JDMather
Message 6 of 9
JDMather
@gearjuice
Did you have any interest in how I would have sketched the Rails?
Message 7 of 9
anthonyzepeda1969
I have found that sweeping gives better results than lofting.
Message 8 of 9
JDMather
@anthonyzepeda1969
Can you Attach the *.ipt file of your solution here?
Message 9 of 9
anthonyzepeda1969
I was just making a general statement on my experiences with lofting and sweeping.
Sorry about that.
