Welcome to the forums.
what version are you on will help a whole lot to get your question answered..
There are new options in new releases so without that would be hard to help....
Maybe the shell command with some extruded cuts would be better for this? Looking at your model and trying to figure out what your after... I am still a bit confused
Exactly! Did you do that with the shell command and extruded cuts?
I was wondering if there was a better way.
Here is the file. Use two extrudes. You could have used a shell but you already had the sketch of the walls there so i just used that. Let me know if you cant figure it out.
You have too many dimensions - use Symmetry Constraints (or mirror) in Sketch1 (same as in SWx).
Sketch2 is not needed.
No dimensions are needed in Sketch3 to fully constrain (same as in SWx) and Sketch3 not really needed.
Workplanes not needed (one is a duplication of the XY Plane. (same as SWx)
Sketch4 only needs 2 dimensions. (same as SWx)
See attached file.
