Loft with rails giving errors
mschena1148
Message 1 of 8
mschena1148
I have a loft that I am trying to create between two dissimilar shapes and 3D rails. Whenever I try this, I get an error telling me that my rails are not smooth, but they are.  I have included the example. My rails are two 3D sketches shown by the yellow lines.  What am I doing wrong?
Replies (7)
Message 2 of 8
blandb
I recreated the vertical arcs that are used to make the intersection curves, and it works fine... Not sure what was wrong initially.
Autodesk Certified Professional
Message 3 of 8
johnsonshiue
Hi! I took a quick look at the part. The rail in 3D Sketch5 is too drastic. It has a short portion parallel to the profile progressive direction. It is not a desirable rail.
The curves in Sketch10 lack a tangent constraint. Please add it. Then 3D Sketch6 can be used as a rail to Loft.
Many thanks!
Software Test Engineer
Message 4 of 8
mschena1148
Can you show the output? What did you do to redraw?
This is the error that I get. The curves are smooth and interset with the two sketches that I am trying to loft
Create loft feature failed
Loft Example.ipt: Errors occurred during update
Loft1: Could not build this Loft
The attempted Loft operation had problems with the specified rail curve not being smooth. Try with a different rail or try to make the curves of the rail smooth across interior vertices.
Message 5 of 8
mschena1148
Hi Johnson,
  Can you show me a screen shot of the output. I cannot get it to loft at all. I'm not sure what you are constraining for tangency.
I get the error
Message 6 of 8
JDMather
@mschena1148 wrote:
Hi Johnson,
Sketch10 was missing Tangent constraint between these two curves.
There are other issues as well.
If I build one surface at a time I observe that there is a self-intersecting issue.
Additional rail or section profile is needed.
Message 7 of 8
blandb
I must have made the rails a little different and unintentionally removed the intersecting curves as @JDMather had pointed out and that is why mine worked...I assume.
Message 8 of 8
mschena1148
Thank you for your help. It was the tangent constraint for sure!
