Flat pattern
Flat pattern
dammerswillly
Observer Observer
Flat pattern
dammerswillly
Observer
Observer
I’m searching for the right information to get the flat pattern that I need.
I’m drawing a profile that’s 2mm thick, for example I have drawn 1 90degr profile both sides 50mm. From
that I want to get a flat pattern that is 98 mm wide.
how to get there?
im just drawing 90 degree angles for now.
James_Willo
A picture would really help here.
To get a flat pattern you just need to click the 'create flat pattern' on the sheet metal ribbon, assuming you created it from a sheet metal template file.
Your blank size will be also be determined by the kfactor used as the metal stretches slightly as it's bent.
James W
Inventor UX Designer
James_Willo
Also have a look at this.
https://autode.sk/3J0Qsju
James W
dammerswillly
Observer
Observer
Thank you,
But for our machines we use exact 98mm.
If we have more bends this 98,2… wil cause an issue whilst programming.
James_Willo
Yes, you will need to include the correct k factor, I guessed at 1.
James W
dammerswillly
Observer
Observer
Thank you I will have a go at this.
