Inventor Forum
Loft Rail Curve Repair
4 REPLIES 4
ethan_howardMMXXIV
381 Views, 4 Replies
ethan_howardMMXXIV
Hello Community,
I made a change to this part and now one of the Loft features is failing. The Design Doctor says to repair the rail curve because one or more rails are not intersecting the sections. I've used constraints to lock the curves to both sections and it still is failing. I know you guys are gurus. This is what it should look like:
Thank you,
-Ethan
Autodesk Inventor Professional 2022
64-Bit Edition
Build: 287, Release: 2022.2.2 - Date: Fri 02/11/2022
Hello Community,
Thank you,
-Ethan
64-Bit Edition
Tags (1)
Labels (1)
  • Loft
4 REPLIES 4
ethan_howardMMXXIV
Still not working.
Still not working.
CCarreiras
Hi!
Tip:
Clean your sketch... project only the geometry you need, and turn in construction geometry the geometry you don't need to select for the tools.
Reconnect the points in the image....and that's it...
File attached, v2023.1
CCarreiras
Hi!
Tip:
CCarreiras
ethan_howardMMXXIV
Thank you
Thank you
johnsonshiue
Hi! Another approach I would consider is to create a Loft surface between the two profiles without using the rails. Then use Sculpt to remove the unwanted portion from the body.
Many thanks!
Software Test Engineer
Many thanks!
