Loft Issue
Loft Issue
perrakis_alexandros
Loft Issue
perrakis_alexandros
Hello Guys,
i am trying to create a loft (cut) between two sketches along two rails and the edge of the part. When the action is carried out a very thin surface is left, which do not want. I cannot seem to get rid of it without extruding a cut which i do not want to as it maybe create problems when i use the geometry further for CFD simulations. Find the IPT enclosed.
kacper.suchomski
Hi
You can use Delete Face tool.
(view in My Videos)
Kacper Suchomski
RajSchmidt
Simply tag a bit of extra geometry onto the first sketch.
johnsonshiue
Hi! I thought this issue was discussed a few weeks ago. Have you tried the solution I proposed?
https://forums.autodesk.com/t5/inventor-forum/cutting-and-contour-using-sweep/m-p/13604556#M950396
Many thanks!
Software Test Engineer
perrakis_alexandros
@johnsonshiue  Hello!
i tried your solution and it was brilliant but then i realized that the shape at the end does remain a half circle and i becomes "distorted" which i do not want. Thank you for replying again and have a nice day!
