Loft is this done right
unocom15
Observer Observer
unocom15
Observer
Observer
Why is it not solid. I have tried everything i can think of.
  • Loft
CCarreiras
Hi!
The lofts are surfaces at the beginning because you had to build each wall (internal and external) separately, in two steps (two loft features)... and that's ok, it's a correct approach.
Now, you have to turn these boundaries into a solid.
A good approach for this case is to use SCULP tool.
Just select the internal and external walls, and since they create a closed volume, sculp will turn this closed volume into solid.
Check the vídeo:
(view in My Videos)
CCarreiras
unocom15
Observer
Observer
Thank you. that helped alot
blandb
I don't have 27 installed, but could the first loft have been a solid, and the second loft been a cut of the first loft to make the inner opening instead of surfaces/sculpt?
Autodesk Certified Professional
CCarreiras
Hi  @blandb , not in this case due lip in the bottom loft.
CCarreiras
