Tell me if I'm being stupid but when creating a loft i can select the inner circle and the two together but cannot select the outer ring. i have tried waiting for select other. Does anyone else get this?
I am revolving the part but thought it's worth mentioning,
Somewhere in my mind I seem to recall someone telling me that you cannot loft a "shell". Only the whole thing, and then do a loft->cut.
I suspect that's the issue here.
Hi! Yannick is right. Loft only supports single-loop profile per section. You can only loft from one loop to another. In your case, you can create the loft based on outside loops. Then create a loft cut based on inner loops or create a shell.
Many thanks!
Attach your *.ipt file here if you can't figure it out.
