Loft command - Reducing elbow (rectangular to circular)
nsatheesan34D64
Message 1 of 19
nsatheesan34D64
Hi all,
How can I make a 24" x 40" rectangular to 36" circular elbow (shown below) using loft command ?
Can someone upload a sample ipt file? Thanks
Accepted solutions (4)
Replies (18)
Message 2 of 19
JDMather
@nsatheesan34D64
Attach the *.ipt file of your attempt here.
Message 3 of 19
Oh my.....does this bring back memories.
My specialty back when I was on CADDS5i (yes, I'm that old) were transitions like this.
In Inventor, the trick is finding the "sweet spot" when it comes to the guide curves. You'll need to experiment on finding out how many is too little and how many is too much.
Let me see if I can demonstrate and post some pics for you.
Message 4 of 19
nsatheesan34D64
@JDMather @Anonymous
Thanks for the reply. Pls find attached the ipt file of my attempt . I need to make two elbow.. 90deg & 45deg config.
Message 5 of 19
89198826955
1. draw part 1
2. draw part 2
3. command "loft"
4. ok
Message 6 of 19
JDMather
@89198826955
That doesn’t look right?
Message 7 of 19
89198826955
it was an example
measurements are required for accuracy.
Message 8 of 19
nsatheesan34D64
@89198826955 Can you attach the ipt please. Thanks
Message 9 of 19
JDMather
@89198826955
Make up some dimensions.
Parametric dimensions can be edited as needed.
Message 10 of 19
89198826955
made based on your file
Message 11 of 19
89198826955
@JDMather can i get some lessons from you?
i looked at your youtube
can i get your email?
Message 12 of 19
nsatheesan34D64
Hi @89198826955 Thanks!
Unfortunately, I am using Inventor 21. Could you please send me a screengrab / pic of the model tree & with loft command menu. Sorry for the trouble..
Message 13 of 19
89198826955
Message 14 of 19
89198826955
1 correct sketch 1 specify thickness
2 correct sketch 2 specify thickness
3 create a work plane with the desired angle
4 cut detail
5 surface loft
6 add thickness
Message 15 of 19
kacper.suchomski
Hi
Look this:
*Random dimensions
Kacper Suchomski
Message 16 of 19
My apologies, *%#@^ hit the fan here right after I posted my reply here and I haven't had the chance to even attempt such. But I'm glad many others here have chipped in to help.
As I've learned in the past, and as I've posted, put in the basic guides and then adjust accordingly to avoid any twist or abrupt corners, etc. This may mean you'll need to add or remove guide curves.
Message 17 of 19
chris
Are you just trying to get the shape or do you need to flatten this when you are done?
Message 18 of 19
nsatheesan34D64
Thanks a lot @chris @Anonymous @kacper.suchomski @89198826955 @JDMather
@chris - Yes, I am making arrangement drawing now.. Need to give  a flat pattern as well for the fab drawing.
Message 19 of 19
kacper.suchomski
Manage tab -> Create components.
Export all solids to separate parts and save the assembly.
Open every part; create Rip; generate a flat pattern.
Kacper Suchomski
