Duplication of a circular pattern
m.konopacki25
Message 1 of 11
m.konopacki25
How do I duplicate those two circular patterns down the cylinder around 40 times?
Replies (10)
Message 2 of 11
Gabriel_Watson
Do a Rectangular pattern and pick the circular pattern to duplicate, then add the cylinder axis as direction 1.
Message 3 of 11
JDMather
This can be done in one pattern.
@m.konopacki25
Attach your •.ipt file here.
Message 4 of 11
m.konopacki25
So the pattern needs to go down until the circles reach 166mm as shown in the attached image. Also, I just realised that the holes aren't hollow so that pattern also has to have hollow holes.
Message 5 of 11
kacper.suchomski
Hi
You can make one pattern and then delete the excess faces, or you can make separate patterns for each circular pattern.
Feel free to experiment with the number of repetitions as you create the pattern to see the effect.
Kacper Suchomski
Message 6 of 11
JDMather
@m.konopacki25
Your sketches are not fully defined?
What happened to diameter dimension in Sketch3?
Why did you use Emboss rather than Extrude?
Message 7 of 11
m.konopacki25
I was following a tutorial of a guy doing patterns around an Ikea lamp and when he used emboss, the patterns were hollow so I thought my patterns were hollow but I only realised they were not hollow when I finished my second row of circles.
Message 8 of 11
JDMather
@m.konopacki25
How will the holes be made in the real world?
Will they be made in flat material that is rolled into a cylinder?
What is the link to the Tutorial that you were attempting to follow?
Message 9 of 11
kacper.suchomski
Emboss is good if you want to do it on a 3D printer, or a tubular profile cutter, or a 5-axis CNC machining.
If you want to do it on a milling machine or CNC machining center using drilling, Extrude operation would be better.
Either way, the selection of the feature does not affect the depth of the cut. The depth of the cut is defined inside the operation (in the dialog box).
Kacper Suchomski
Message 10 of 11
m.konopacki25
I don't know what machinery it will be made with yet but it will go through a prototyping stage and I will use a 3d printer for that. Also, it will not be made in flat material rolled into a cylinder but from a purchased pipe with the correct thickness and close to the correct diameter.
Message 11 of 11
johnsonshiue
Hi! I vaguely remember we had a bug in 2023 RTM build. Please install 2023.3 update. The issue should have been fixed there.
Many thanks!
Software Test Engineer
