Inventor Forum
Loft Advice
4 REPLIES 4
765 Views, 4 Replies
Loft Advice
Im struggling coming up with a loft or sweep to get the design effect I need. Please see on the pic how the profile terminates to a point. Any help or advice would be appreciated
4 REPLIES 4
I am a beginner myself, and I am sure someone will come along and give you proper advice, but I'll give it a bash later on.
I'll try a 3d sketch intersect to create the lifted bit, and maybe use split to try to loft bit by bit around that tight corner.
Cheers
blair
Create your round end first, most likely a Revolve to form the end Button. Then create your Sweep from this. You should be able to copy the outer edge of the Button onto the sketch for the profile of the Sweep
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mpatchus
Just a real quick 5 minute attempt, but you can get some ideas from it.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Thanks for your help Mike, I got it
Steve
