load calculation
load calculation
89198826955
Message 1 of 15
load calculation
89198826955
when calculating loads
1 in stress analysis environment
2 in autodesk nastran environment
i have different offset data what
i am doing wrong?
Replies (14)
Message 2 of 15
89198826955
initial data
1 frame 5000x5000x3000 mm
2 profile square pipe 100x100x7 mm
3 load 10000 kg
Message 3 of 15
admaiora
I see a finite element analysis (inventor) and a beam analysis (Nastran).
Am I wrong?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 4 of 15
89198826955
Linear Static in both options
Message 5 of 15
admaiora
No i didn't say that.
The order between tetra and linear elements is different.
From your pic (it seems) you are comparing a linear analysis with tetra elements (in Nastran) with a linear structural analysis in Inventor (beam linear elements).
Admaiora
Message 6 of 15
89198826955
How to do it right?
Message 7 of 15
TheCADWhisperer
@89198826955
Attach assembly here.
Message 8 of 15
89198826955
attached
Message 9 of 15
admaiora
Can you attach it with your analysis setting(both cases)?
Admaiora
Message 10 of 15
admaiora
Inventor 21,38 mm  (frame analysis)
Nastran 21,97 mm (frame analysis)
Admaiora
Message 11 of 15
JDMather
@89198826955
Tip 1.  When you Pack and go - Templates are not needed and usually not Libraries and Styles.
Question 1.
You posted a question about Frame Analysis - yet there is not Frame Analysis in the dataset that you Attached?  How can the issue be diagnosed without the full data?
I don't see your Constraints?
I don't see your Loads?
Message 12 of 15
89198826955
I have attached the experiment file.
Message 13 of 15
89198826955
if there is a video or training video
I will be very grateful
Message 14 of 15
89198826955
I get an offset of 38 mm
1 fixed on the plane
2 plane pressure
(10,000 kg * 9.8) / (0.325 m ^ 2 * 4) / 1,000,000 \u003d 0.076 MPa
 What am I doing wrong?
Message 15 of 15
89198826955
apply force along the plane
