Linear dimension jog to extension lines?
nathan_m_gardner
Message 1 of 8
nathan_m_gardner
Is it possible to jog an extension line of a linear dimension in the draft?
Replies (7)
Message 2 of 8
CGBenner
@nathan_m_gardner
Hello, I do not believe so, but can you show us a picture of what you're trying to do?  Maybe there is another solution.  What version of Inventor?
Chris Benner
Message 3 of 8
nathan_m_gardner
[image: image.png]
Message 4 of 8
CGBenner
@nathan_m_gardner
Hi, your image did not attach to the forum response.  If you were attempting to attach this from a mobile device, that does not work.  You could use the Windows Snipping tool (or a MAC equivalent) and then just copy/paste the screen shot into a reply.  Thanks!
Chris Benner
Message 5 of 8
nathan_m_gardner
Message 6 of 8
johnsonshiue
Hi! I don't believe it is doable with Chain dimensions. You can tilt the dimension lines. But Ordinate dimensions do support jog.
Many thanks!
Software Test Engineer
Message 7 of 8
nathan_m_gardner
I am amazed at how some of these little things cannot be done in Inventor.
Message 8 of 8
johnsonshiue
Hi Nathan,
In terms of 2D drafting workflows, Inventor is not as flexible as AutoCAD. If you like using AutoCAD's 2D drafting workflows, you may use AutoCAD VIEWBASE command to create associative drawing views to Inventor components and use the drafting tools in AutoCAD. When the Inventor components change, AutoCAD will update the drawing views accordingly.
Many thanks!
