- Mute
- Permalink
- Report
Hello.
I am designing a specialized tool. It would be a spreader for taking apart a connector.
I have two points on one part.
I would like to have the same two points projected on another part in the assembly.
I would like two parts to have holes that line up and I would like to build the second part around those two points.
Is it done through I feature? What tab of the I-feature menu do I tinker with to share two points across several parts in the assembly.?
Also I remember that there is a way to cut a hole through several parts. How do I do that?
I may not want to use that.
Those points would have shoulder bolts or pins or rivets running through them. (I will have to talk to the manufacturer.)
I watched the whole TEDCF videos course last year and I already forgot everything. I cannot even find how to do it using their search tool.
I forgot the term for it.
THANK YOU!!!
