Hi. Is it possible to set the line thickness for saved PDF drawings?
In *.idw its like this:
After saving it to PDF its like this:
It needs to be sketched so it would look transparent in DWG files and other versions.
Solved by johnsonshiue. Go to Solution.
Hi! What is the Options you use to export PDF? Did you check "Remove Lineweight option."
Many thanks!
For PDF saving this works but where can I remove line weights while saving to AutoCAD dwg format?
Hi! I am not aware of an option to strip off line weight on exporting to AutoCAD dwg file. You may need to uncheck "Scale to Line Weight" option in the Layers (Drawing -> Annotate -> Edit Layers).
Many thanks!
