hello,
Let me start by telling you i have read thru atleast 5 threads before asking this question.
I am simply sketching and i find that my point snapping is very controlling. It wants to start my line at even interval numbers like x.125 and y .250 (not acceptable) or at endpoints of existing lines in the sketch ( this is acceptable) i have open. example: i cannot start a line in a random point of space say x 3.3655 and y2.1375 it will always snap to the even number closest.
What setting can i change to get around this ?
hello,
Solved by Curtis_Waguespack. Go to Solution.
Hi! I believe it is related to snapping distance. Go to Tools -> Document Settings -> Sketch -> change the snap distance for both X and Y directions.
Many thanks!
Many thanks!
Can you go ahead and complete a part (using whatever technique) and attach it here?
Hi @Anonymous,
You can just turn the snapping off using this button, if that helps:
I
hope this helps.
Curtis
Hi @Anonymous,
I
hope this helps.
Curtis
