Line Path Pattern
Line Path Pattern
serhat_akpinaar
Advisor Advisor
Message 1 of 10
Line Path Pattern
serhat_akpinaar
Hello.
I have a sketch, I want to throw a point pattern on this sketch at certain intervals. I'll assemble the chain with this pattern. Is there a way to do this ?
Serhat Akpınar
Bu gönderiyi faydalı buldunuz mu? Bu gönderiyi beğenmekten çekinmeyin.
Sorunuz başarıyla yanıtlandı mı ÇÖZÜMÜ KABUL ET düğmesine tıklayın.
Replies (9)
Message 2 of 10
JDMather
Attach your *.ipt file here.
Message 3 of 10
johnsonshiue
Hi! Path pattern is only available at feature level, not at sketch pattern level. You can create the workpoint pattern like you showed in the image and project the points to a 2D sketch.
Many thanks!
Software Test Engineer
Message 4 of 10
SBix26
The problem you will have, though, is that you want the distance between points to be the chordal distance, but Inventor's pattern feature uses the distance along the path.  You will have to make your path using line segments around the curve (change the arc to construction).
Sam B
Inventor Pro 2021.2.2 | Windows 10 Home 2004
LinkedIn
Message 5 of 10
serhat_akpinaar
Hi to all,
You can find the sample video at the link below.
https://www.youtube.com/watch?v=Y5mJqJ1fsyc&ab_channel=3DParametricSolidModelDrawing
It belongs to the model .ipt is attached.
Serhat Akpınar
Message 6 of 10
johnsonshiue
Hi! There is actually a way around this. You can leverage pattern of pattern. Please take a look at the attached part.
Many thanks!
Message 7 of 10
serhat_akpinaar
Johnson, thank you for your concern.
But the measurements found in the raduses do not come as exactly 25,000 mm.
Serhat Akpınar
Message 8 of 10
n_Sovljanski
As I can see you need exactly 25.4 mm all along path. If you use "Spacing" option from rectangular pattern this will apply on selected curve. That is meaning arc length is 25.4 but distance between points is 25.1482mm.
I will rearrange your sketch and and posted later .
Message 9 of 10
n_Sovljanski
Hi, here is modified part in attachment and explanation.
First I converted all lines and arc from sketch 1 in construction lines. I have drawn new sketch above. Length for first line must be floor(d44 / Step) * Step (you will see in parameters what is what). Then I have drawn new 5 lines with length = 25.4mm. Then I added new driven dimension (d79=23,099mm) for further calculation. Then I have drawn with length d80=floor(( d0 - d79 ) / Step) * Step. And so on.
Two things are matter:
Straight lines must be n x 25.4mm.
Lines above arcs must be 25.4 mm length with Coincident constraints on both ends.
I hope this helped.
Message 10 of 10
johnsonshiue
Hi Serhat,
I thought you would like the distance between two workpoints to be 25mm consistently right? There is no way to make the arc length the same as the chord length. You can only get either.
Many thanks!
