Line appears on printed drawing
cholmberg42KWJ
cholmberg42KWJ
I have both printed a physical drawing and used the Print to PDF option, and for some reason this line shows up when I print my drawing. It doesn't show up in Inventor at all. Does anyone know why that might be?
Thanks!
johnsonshiue
Hi! The behavior is wrong. It could be a corrupted view border or a piece of corrupted geometry. Try copy the sheet and paste it to a new drawing. Then print to PDF. Does it work better now?
Many thanks!
Software Test Engineer
cholmberg42KWJ
I tried copying the sheet and putting it in a new drawing, but that made no difference. The line is still there on the printed drawing.
cholmberg42KWJ
After some trial and error, I found that when I right-click on the Right Side view and disable Drawing Dimensions, under Annotation Display, the line no longer appears when I print the drawing. So it's obviously a problem with a specific dimension. Is there any way I can narrow down which one it might be, or do I have to just manually go through and delete each one to find the culprit?
johnsonshiue
Hi! Unfortunately, I am not aware of a way to detect the culprit. It looks like a corrupted dimension. If you know how to reproduce it from scratch, please let us know asap.
Many thanks!
