I'm new to using limits in the constraints but now it could be usefull.
But when I add limits the item can be moved further then the actual offset, what am I missing?
Thanks in advance!
Best regards,
Bob
Solved by mcgyvr. Go to Solution.
Share your example .... probably be easier that way
Did you add a "min" and "max" for that constraint?
This is the assembly where I encounter the problem. It is still version 2014 could that be the reason?
I forgot to insert the screencast on my first post sorry.
Try using an insert constraint instead of mate..
