I recently installed Inventor 2017. When creating a new .ipt the Lighting Style comes up as "Grey Room" on the View/Appearance panel. How can I change this so that a new .ipt defaults to "Two Lights" or "One Light"...or something else? When I create a new .iam the Lighting Style is preset to "Two Lights".
I also noticed the "Default" Lighting Style that was present in 2016 is gone.
Solved by mcgyvr. Go to Solution.
edit your template.. change to the lighting style you want.. save template..
