I'm designing a lift lug for 25000lbs. Minimum required factor of safety is 3. My FEA results show maximum stress 19.89ksi - way to high for A36 material.
I used a bearing force in Inventor and tried the same in Solidworks with identical results.
I did some simple hand calcs and stress was significantly lower.
Then I found this calculator:
https://mechanicalc.com/calculators/lifting-lug-analysis/#divResults
This calculator is using an Air Force Method and my lug would pass with safety factor grater than 3.
I'm fairly new to FEA so I did some googling and found this video talking about St. Venant's Principle:
https://www.youtube.com/watch?v=TgpM6xOTfuE
Could anybody comment on this?
