I have made a container for offshore lifing
i need to do a stress analisys what its lifted in the corners in wires
how do i make wires to a crane hook ?
Solved by JDMather. Go to Solution.
Hi!
Design the cables... will not be easier to recreate the real scenario.
I wouldn't design the wires.
You know the total weight of the model.
Check the cable specifications and select those who can manage that weight.
Hi!
There is an example of this in the Wasim Younis book.
Then hov do i calculate the compression of the top beams ?
the dnv standard needs the wires in the fea
