I know there's a separate installation board, but the answer they give here
(the gfx card) does not apply to my system, and deleting/renaming the files as they suggest does not help.
In brief when I launch inventor what happens is;
-the splashscreen appears and the progress bar goes to ~25 percent
-the autodesk licensing window appears
-a popup saying "autodesk component has stopped working" appears and the whole shebang crashes to desktop.
Reinstalling the entire PDS(U) did not help. Deleting the files as they describe in that link does nothing but makes them reappear after inventor is launhed.
Many thanks in advance for any help
Joe
Solved by ChrisMitchell01. Go to Solution.
I don't see where you state -
- what version of Inventor this is?
- what OS this is?
- condition of AUC and anti-virus during install
- is this a new install, or is it an install that had been working previously, and now this is a new problem
- if this is an old install that was working, did you return to the Windows Restore Point you created after the successful install?
- if this is a new install that never worked, did you find the Autodesk Clean Uninstall instructions (including Registry edits)?
Did you install SP 2 if 2014
or
SP 1 if 2015?
Do you have the Internet Explorer Security update KB2977629 installed ? (released several weeks ago).
If so try uninstalling that from Control Panel, Programs, View installed updates, & then retry your activation.
Chris
Sorry for the lack of data, I was a little tired last night. To answer your questions; Product Design Suite Ultimate 2015 on win8.1 x64 WITHOUT SP1.
I looked for clean uninstall instructions, there were several. Could you point me to the correct ones for my version please?
Thanks again for your help
EDIT: I have no antivirus besides windows defender, and both windows defender and UAC were on. I will attempt to disable later on this afternoon.
Joe
Always a good idea to turn them off when installing anything more complex than Notepad. Most malicious activities are very similar to valid installs so they can get underfoot with the complex installs. Just don't forget to put them back on later (although many power users leave UAC off).
Yea that did it
Wasnt the judge supposed to make M$ dissassociate IE from the OS? Looks like its a work in progress
