Level of Detail for Parts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Curtis_Waguespack has posted the following idea in the Inventor IdeaStation for LOD parts: http://forums.autodesk.com/t5/ideas/v2/ideapage/blog-id/v1232/article-id/1401/page/1#comments
Autodesk has marked the idea as "Accepted", but I'm wondering if anyone has come up with a decent way to mimic this functionality until Autodesk implements it?
With iParts, when I change an iProperty (such as Stock Number), or do any other sort of change while in "Factory" mode, that change should be shared with ALL members unless it's explicitly added to the iPart table--but that's not the case. iProperties are not shared with all members--I have to explicitly add them to the table and keep them in sync manually, or the property doesn't show up right on drawings. We use custom iProperties as well, some of which are created at the Assembly level by iLogic, and these are a pain to keep up to date with iParts.
With derived parts, there just isn't enough control over the part's features. I can remove some basic featuers (like fillets), and I can add features, but that's about it. In addition to this, not only iProperties but even more surprisingly, the material is not derived into the derived part, and there's no way to create this link. If the material of the base part is changed, it's possible drawings of the derived part could be produced and handed out with the wrong material and you'd never even know it, unless you remembered to update all of your derived parts (and knew that was necessary in the first place).
So, until LOD parts are implemented, does anyone know of a way to have the feature-control of iParts but still maintain shared iProperties between members? Or how to achieve the same linked iProperties (and material) with Derived parts?
Thanks for any suggestions 🙂
