Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Length shows incompatible error when trying to make a static value of 'X"
mark.mendozaM92R3
mark.mendozaM92R3
Is there anyway to make a static value for Length, when i try to change the length  of a virtual part, it doesn't cahnge and shows an  error of incompatible units,
CGBenner
@mark.mendozaM92R3
Hello, and welcome.  Can you share some more information, please?  What version of Inventor are you using?  How is your length column set up?
Also just noticed that you have (2) #24 in your BOM.  Could that be causing the problem?
Chris Benner
johnsonshiue
Hi! I guess you will need to check the "Length" unit or the parameter unit for the QTY. They need to be consistent.
Many thanks!
Software Test Engineer
