Learning: creating a wood panel
Hi guys,
I have just started to learn how to use Inventor.... I am loving this software so far but finding difficult to learn on my own.
I am trying to create a rectangle panel wood with sides with different angles (700x1000mm and thick of 15mm) 2 sides need to be 45degres and the 2 other 25degres.
I have tried withh the Extrude and taper function ...but this doesn t let me create different angles(taper) on each sides.
What would be the best way to do this? What other function could i use?
I hope i was clear enought!
Thanks in advance
blair
extrude your profile with square sides, then use the Chamfer command. You could also create a sketch on the side of panel, produce a triangle of the shape of the material you wish to remove and use the extrude command, but with the "cut" option.
Delta Tau Chi ΔΤΧ
Super! thanks Blair....i learned how to use the Chamber command...It is exactly what i need! thanks for the help
