Leader annotation pulls part number from part rather than assembly
38ten.pq
38ten.pq
Hi Folks,
I'm using the Add text parameter to pull in the part number of an assembly in a leader annotation. My problem is that the part is referenced rather than the assembly that is the subject of the drawing and forms the base view on the sheet.  A different sheet correctly references the sub assemblies of a larger assembly when using the auto balloon feature so it feel like a BOM structure issue but don't know where I can change that?
Any ideas?
-niels-
I'm confused, are you using a leader or a balloon?
If using a balloon, then it might be because of the assembly being expanded in the parts list if you're using a "structured" BOM.
If you are using a leader, then i'd have to test your procedure so it'd be nice if you could give a bit more detail.
I'm not 100% sure, but i think you can't reference the main subject of a view with leaders.
You can add referenced data of the main subject in a view label though...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mcgyvr
Thats just how Inventor works when using leaders..
Vote here to show support for adding functionality to allow you to pull from the assembly with a leader..
https://forums.autodesk.com/t5/inventor-ideas/improve-leader-text-to-pull-subassembly-iproperties/id...
38ten.pq
I thought this was going to be the case! Voted for the feature but it looks like it's stale sadly.
Thanks both!
