Inventor Forum
lbmass in TB
4 REPLIES 4
379 Views, 4 Replies
lbmass in TB
Does anyone know how to remove the "lbmass" text that shows up when I add the Physical Property "Mass" to my title block? Inv. 2008.
Thanks in advance.
4 REPLIES 4
Edit Parts List.
RMB on the Mass Column and select "Format Column"
On the first tab, check on "Units Formatting" then uncheck "Unit String".
QBZ
wrote in message news:5728886@discussion.autodesk.com...
Thanks in advance.
Thanks for the quick reply.
However, I am not using the parts list as my title block. I have created a border that calls the iproperites from the model and the text editor for the iproperty does not have a units formatting option. Do you know of a fix for this one?
Sick. I read that one well! (not)
Yippee Pro will do this effortlessly because it can format ANY
string/property properly. (it creates a custom iProp that auto-updates and
can be pulled into the TB through the model-custom iprop function)
I know it works in part files in R11 but I haven't got it loaded on my R2008
machine.
Adesk's lack of foresight in the realm of formatting is astonishing to say
the least. (look at concatenation of functions in R2008 )
QBZ
wrote in message news:5728895@discussion.autodesk.com...
this one?
