Inventor Forum
Layout Import Options Screen
1 REPLY 1
RosaQ
232 Views, 1 Reply
My coworker and I need to import mechanical desktop files into inventor.  After the update for Inventor 2015 this screen appears to be blank, if I hold and drag it I can see the options but when I let it go it appears blank again.  I have to guesstimate where the box to translate parts/assemblies is, if I click next without checking that box the program faults and it has to be closed thru the task manager.  I have tried reinstalling the graphics driver and running a repair then a reinstall for inventor and the problem persists.
I have attached a screen shot of the blank window.
1 REPLY 1
johnsonshiue
in reply to: RosaQ
Hi! This is a known issue with Inventor R2015. We are currently working on a solution to address it. I am very sorry for any inconvenience it may have caused. If this is a blocking issue to you, please send me an email (johnson.shiue@autodesk.com) and I would like to explore some options with you.
Many thanks!
Software Test Engineer
