Inventor Forum
Latest Updates | Recent Knowledge Base Articles | March 2022
0 REPLIES 0
Message 1 of 1
CGBenner
230 Views, 0 Replies
3/29/2022
How to delete the iProperties in a step file before importing it as an Inventor model.
3/28/2022
Inventor iLogic rule is triggered without reason during check-in to Vault 2022
3/28/2022
A part in an assembly can't be found with Inventor's search tool
3/28/2022
How to extract an iFeature or a Punchtool successfully
3/28/2022
3/28/2022
3/28/2022
Lagging and Inaccurate�results in dimensioning and measuring are experienced, when using Copy/Paste ...
3/28/2022
When moving a flexible assembly, the constraints are not kept within the graphics window in Inventor
3/25/2022
How to change default base units for frame member profiles in Inventor
3/25/2022
STEP file created in Inventor 2018 imported not correctly in Siemens NX 1980
3/25/2022
"Inventor import requires Apprentice Server" when using Esprit CAM and Inventor at the same time
3/25/2022
Missing Vault DLL in Inventor when running iLogic
3/25/2022
Need to set origin point for exchanging Inventor files to Revit
3/24/2022
"Unspecified error" or "Run-time error"  when using BOMView.Sort2() API function in Inventor
3/24/2022
How to add a new asset category in the Inventor material library using API???????
3/24/2022
"Autodesk Analytics Client Service has stopped working" when opening and closing Inventor
3/24/2022
"Unable to open file. File's extension (...)" when opening Frame assembly in Inventor
3/24/2022
Export to IFC from Inventor hangs or can't complete
3/24/2022
iFeature punches generate rotated by 90 degrees in Inventor
3/24/2022
Questions on isometric hatching for half-cut cylindrical parts in Inventor drawings
3/24/2022
Revit export in Inventor hangs
3/23/2022
Geometric results for fillets are different in similar Inventor parts
3/23/2022
Item name/number cannot be changed when in presence of model states in an Inventor assembly's BOM
3/23/2022
"Topology belongs to more than one bend" when�creating flat pattern from metal sheet part which incl...
3/23/2022
After changing components and switching the model state the custom iParts are replaced by the standa...
3/23/2022
How to export iProperties to RVT from Inventor
3/23/2022
Inventor crashes when saving a drawing file
3/22/2022
Edge of a sheet metal flat pattern not exporting correctly from Inventor
3/22/2022
How to show the total quantity of parts inserted in several instances of Inventor assembly's subasse...
3/22/2022
Properties from model not filling in title block in Inventor
3/21/2022
Long hangs when creating, editing or deleting dimensions on large assembly drawings
3/18/2022
There is no flexible command in the context menu In Inventor top assembly
3/17/2022
Inventory crashes when opening and viewing simplified model
3/17/2022
Cannot access Content Center within Inventor
3/17/2022
DXF exported from Inventor include gaps in the profile after importing it to AutoCAD
3/17/2022
Exporting Inventor drawing to DXF gives incorrect lines types
3/17/2022
Problems when trying to mirror or pattern a boss feature in Inventor
3/17/2022
Sweep cannot be recreated by adding another part of path in Inventor 2022.
3/16/2022
A parameter linked to another parameter doesn't update in Inventor
3/16/2022
After changing Revit model Inventor 2021 does not offer any update
3/16/2022
Dimension error shown when referencing Revit Model in Inventor 2021
3/16/2022
Sheet Metal Parts edited in Inventor 2022 generate unexpected errors
3/16/2022
View in Inventor is different compared to Revit when referencing Revit file in Inventor 2021
3/15/2022
Parts list that includes iParts are not showing the correct member length in Inventor
3/15/2022
The density in the properties is not correct in Inventor 2021
3/15/2022
"Cannot read texture image (filename.dds)" when opening drawings in Inventor 2022
3/15/2022
Fillet or Chamfer get corrupted after updating an Inventor derived part
3/14/2022
Dimension cannot be created on sketch geometry in Drawing view in Inventor
3/14/2022
Incorrect contour after exporting flat pattern face to the DXF file in Inventor
3/14/2022
Measure command gives wrong values on angles when showing all decimal places in Inventor
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
0 REPLIES 0
Technology Administrators
