Created Date
Product Name
Knowledge Article
5/2/2022
Inventor CAM - Ultimate
Selecting G95 for tapping or drilling operations in Inventor CAM, HSMWorks, or Fusion 360
5/2/2022
Inventor
Slow to open files from Inventor
5/3/2022
Inventor Professional
The Quick Access Toolbar did not migrate into Inventor 2023 from Inventor 2021 as expected
5/3/2022
Non-derived elements get visible once editing the deriving options in Inventor
5/4/2022
The 'new standard folder' and other data standard actions are missing in Vault right click menu
5/4/2022
Inventor Nesting
Cannot create a nest of an iAssembly in Inventor Nest
5/4/2022
Export hi-res image with note from Inventor part shows duplication
5/5/2022
Identical frame components are listed with different *varies* in column REV in BOM
5/5/2022
Sx (in^3) column is empty for Content Center in Inventor
5/5/2022
Inventor
The Center of Gravity (COG) is not updating correctly by using the iProperties Mass Update in Invent...
5/6/2022
Inventor
Weld beads stay visible when they are deleted in Inventor 2021
5/6/2022
Inventor
Insert content center parts on a new install of Inventor crashes back to desktop.
5/6/2022
Cannot see the full path of the "Copy from" dropdown list when using Inventor Design Assistant to co...
5/6/2022
Inventor
For Imported STP files, Direct Edit Radius is behaving differently in Inventor 2023
5/6/2022
Inventor
Skewed shaded Views when publishing PDF in Inventor
5/6/2022
Crash on opening Inventor 2021 Assembly "NBNotebookSegment"
5/9/2022
Inventor Nastran
Parts pass through each other in an analysis with Inventor Nastran
5/9/2022
Inventor
Is there a quick access menu for properties in the title block of an Inventor drawing
5/9/2022
Inventor
Inconsistent revisions in drawing when using iParts or iAssemblies in Inventor
5/10/2022
The visibility of many parts in a particular assembly was unexpectedly changed in Inventor
5/10/2022
Excel Parameters converted into User Parameters when creating a new Model State in Inventor
5/10/2022
File path for Inventor STEP files is included in metadane and can be seen in online viewer
5/10/2022
Unable to move a component constrained to surface which include pattern in Inventor 2023
5/10/2022
After a restart, Vault buttons are missing in the Quick Access Toolbar in Inventor
5/11/2022
Can't open AutoCAD files in Inventor after crash of server
5/11/2022
Are the model states relationships kept between an Inventor Assembly and its Sub-Assembly when it's ...
5/11/2022
Texture position of Inventor appearance changes when switching from Realistic to Shaded visual style
5/11/2022
When creating a spur gear, factor of safety from Pitting has big, negative value in Inventor
5/11/2022
Can the part number be shown in the browser in place of file name in Inventor
5/12/2022
"There are small gaps between these edges." when generating Core and Cavity in Inventor
5/12/2022
iAssemblies BOM rows merged without any obvious reason in Inventor
5/12/2022
Mirrored holes in assembly show up in browser but not is the part in Inventor
5/12/2022
Animating a camera in Inventor Studio leads to the camera rolling around the view axis
5/12/2022
"invalid argument type" error message when rules are triggered in Bolted Connection templates after ...
5/12/2022
Inventor
IFeature Will not Show Hole On Secondary Solid in Inventor
5/13/2022
A flexible sub-assembly inserted into an assembly will no longer flex in Inventor
5/13/2022
Inventor
Lost adaptivity when migrating file to newer release of Inventor
5/13/2022
Where to get information about Ansys Workbench add-in for Inventor 2023
5/13/2022
The expand of position section isn't remembered in Measure command in Inventor
5/13/2022
Graphics not working in Inventor
5/13/2022
Inventor Nesting
How to convert the bend lines styles to dotted in the exported DXF from Inventor Nesting
5/13/2022
Weird behavior for assembly with certain parts seem way off in the distance and the graphics are als...
5/13/2022
Inventor Nesting
How can the Material Cost, Total Area, Area, and sub-assembly in the Sheet part Summaries Section be...
5/13/2022
Navisworks 2023 is not able to open a model upgraded to Inventor 2023
5/13/2022
Inventor
No iFeature definition in mirrored component in Inventor Sheet Metal Flat Pattern
5/13/2022
Inventor Nesting
Can the correct G-Code be created from Inventor CAM when bringing in an IAM created from Inventor Ne...
5/13/2022
Problems encountered while saving Inventor document
5/16/2022
Parameters linked in an Inventor file always received from [Primary] Model state
5/16/2022
Can you place a second point cloud in relationship to the first in Inventor
5/17/2022
Inventor
Using an older version of Inventor closed file and now needs to be opened in newer version of Invent...
5/17/2022
Tube & Pipe module missing from Inventor
5/18/2022
First line containing 80000000 as a part number will not register within Content Center in Inventor
5/18/2022
Error "Could not find the specified file. Please select a different source file" is generated when u...
5/18/2022
5/18/2022
In Inventor Recent documents sorting on home page is not honored when the Regional Format is set to ...
5/18/2022
5/18/2022
Tolerance not updated properly from model state in Inventor
5/18/2022
Suppressed components with QTY unit other than ul still listed in BOM Inventor 2023
5/19/2022
'Save Copy As' of Inventor Flat Pattern with 'Merge Profiles into Polylines' option leads to wrong g...
5/19/2022
The component array appears in all model states previously created in an Inventor Assembly
5/19/2022
5/19/2022
"Rebuild All" disturbs the dimension applied to the 3D sketch in Autodesk Inventor
5/19/2022
"The database could not be opened" when opening Inventor drawing and DWG files becoming corrupted
5/20/2022
When opening a DWG file nothing comes in to Inventor
5/23/2022
Section analysis does and show resaults in Inventor
5/23/2022
Inventor
"Failed to Connect. Link may be broken." when editing Excel tables in Inventor
5/23/2022
Dirty flag appears opening layout with multiple Factory layouts in Inventor with Vault
5/23/2022
Inventor
5/23/2022
5/23/2022
5/23/2022
5/23/2022
5/23/2022
Inventor
5/24/2022
When using Vault Open From vault inside Inventor with shortcuts, an Assembly does not open
5/24/2022
Content Center Part shows old values after updating an Inventor Content Center library
5/24/2022
How to run Inventor without visual basic
5/24/2022
Inventor
Is there a Human model with gripping widths visualization
5/25/2022
Vault browser does not show the correct status of substitutes in Inventor
5/25/2022
Sheet metal cut does not remove material when option "Cut normal" is used in Inventor
5/25/2022
Dragging a component with activated contact solver in Inventor leaves a gap instead of stopping at e...
5/25/2022
Visibility option is grayed out when marking components and sick relationships icon in Inventor
5/25/2022
Inventor
When changing the Precision in the Measure command, the Document Settings are changed in the Invento...
5/25/2022
Frame Generator freezes when selecting "OK" to permanently insert the frame in Inventor
5/25/2022
Inventor
Sheet metal flat pattern not available in Inventor View when used with MasterCAM
5/26/2022
Inventor
Invalid Stoul Argument is received when opening a drawing in Inventor 2020
5/26/2022
Profile roughing toolpath fails to generate in Inventor CAM
5/26/2022
A change of diameter from 20000 mm to 20001 mm, the cut operation becomes failed in Inventor
5/26/2022
A3 paper size for HP OfficeJet 7610 doesn't show up in Inventor
5/27/2022
Inventor stops working when using "o" letter in Mark Feature
5/27/2022
Inventor
Projected Geometry Turns purple After Finishing Sketch in Inventor
5/27/2022
Inventor
How to turn off "Automatically Convert Constrains to Standard Joints" in Inventor Dynamic Simulation
5/27/2022
Is there anything beyond Stress simulation in Inventor
5/27/2022
Newly added balloons are not displaying in the Part List placed in specific Inventor drawing
5/27/2022
Inventor
"An unexpected error occurred" when Inventor recent document window includes files stored in Desktop...
5/29/2022
Error "Failed to create radial dimension" is generated when a sketch fillet is created in Autodesk I...
5/30/2022
Using GetSheetMetalEntity API function in Inventor, returns 'nothing' for some edges
5/30/2022
Inventor
A "Rebuild All" always triggers a save in Inventor, after opening a pre-saved file
5/30/2022
Extrude feature used with "Asymmetric" direction with the "To" option, switches to Default direction...
5/31/2022
Sketch becomes corrupted when tried to offset projected cut edges in Inventor
5/31/2022
Parameters show formulas in BOM instead of value in Inventor 2023
5/31/2022
Incorrect representation of a hidden DWG overlay in IDW drawing in Inventor
