Key way
Key way
Key way
Where do I find a tool to cut a key-way in Inventor?
JDMather
Extrude - Cut
Do you need some examples.
There is probably already an iFeature.
Let me see if I can whip up a video.
Certainly. Examples would be nice.
LT.Rusty
In the assembly environment, you can also go to the DESIGN tab and hit the KEY tool on the POWER TRANSMISSION panel.
Rusty
JDMather
Here is a video that shows several different keyway styles and techniques.
Turn on your sound.
For the last keyway I should have picked a different face than the end of the part, but I didn't want to bother to redo the video for something as simple as a keyway.  When all else fails, Extrude - Cut. Done!
I just realized that I forgot to demo iFeature.  Frankly, it would take me longer to do that than simply create the sketch and extrude.
