アセンブリ パターンについて、質問があります。
パターンをするコンポーネントの列の数や行のピッチを変化させる事は、可能ですか?
可能であれば、どのような操作をすれば良いでしょうか?
教えてください。よろしくお願いします。
Solved by mcgyvr. Go to Solution.
First of all, welcome to autodesk forum.
I have translated your issue to English:"
On the pattern assembly, there is a question.
It is a component of the pattern changes in the pitch of the column and row number, is it possible?
If possible, I would do well to what?
Please let me know. Nice to meet you."
It seems you have questions as Component Pattern, could you inform me which version are you using?
I have created one simple Pattern, could you check whether it similar as what you want?
If not, could you show one image for your question?
Hope this helpful for you.
Hi
Nice to meet you, JoyceZhou
Thanks for the message
Please see the accompanying illustration
I want to change the size of the row and number of column
パターンコマンドを使って、コピーの数や寸法を変化させていきたいです。
宜しくお願いします。
If you have Inventor 2017 there is a new feature of sketch driven patterns that can accomplish your "non-pattern"
