Hello, 🙂
I've created an iFeature and I removed Thickness(0.9 mm) as Inventor felt it was a question to be asked, having created the the iFeature I tested it and it cut to the depth of 0.9 mm, I changed the Sheet Metal Thickness and the cut depth remained unchanged. Is it possible to always use Thickness as a Cut depth in an iFeature without being a question/prompt?
Thanks in advance for your help.
Scott
Solved by Gabriel_Watson. Go to Solution.
Assuming you defined your cut/removal using a simple extrude, you had to type in that distance somewhere, and you could simply use the "Thickness" parameter instead into the same field as a formula. Extract the iFeature as such and you should be ok.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
In the picture there is the Size Parameters section, I have removed the prompt "Enter Thickness" as I wanted the iFeature to pick up the parameter "Thickness" from the file in which the iFeature is placed, unfortunately Inventor seems to need a numerical value or prompt in there somewhere. I hope that makes sense.
Hello, 😁
Thank you fella/bud/mate... delete as appropriate. 😊
It's funny in that we edit the prompt and delete the "Prompt " text leaving just "Thickness" without actually deleting the Question and Inventor not only doesn't ask the question but also finds the Parameter I need.
Many thanks for your help. 😊
Scott
This is why so many companies are looking for UI/UX designers, lol...
You're welcome bud.
