IV2018 - "Export Face As" - Defaults to Yellow / Dashed linetype??
RobSinglehurst
RobSinglehurst
I have used "Export Face As" for probably 10 years or more to easily obtain a nice clean dxf with standard white and normal linetype for then using with our laser software.
In IV2018 (installed on Friday) I am getting yellow / dashed linetype.
Does anyone know where the setting are to put this back to the defaults?
Cheers,
--Rob
Inventor 2024.2
admaiora
Hi Rob,
i have just tried and i don't have that issue. Just normal clean, not yellow, lines
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
RobSinglehurst
I'll have to do a bit more digging to see what I've broken! Smiley Happy
Cheers,
--Rob
Inventor 2024.2
blair
Try an older version of the DXF. By default Inventor will use DXF version 2018. Many people can't open the current version. Try using an older version such as 2008 which can be found in the Options on the DXF Out box.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi Rob,
I am not seeing the behavior. It seems to work fine for me. The lines are continuous and in white color. Do you happen to use any configuration ini file?
Many thanks!
Software Test Engineer
RobSinglehurst
Hi Johnson,
Thanks for your reply. I am not using any .ini file at all. I have sent you an email,
I have just tried saving as an AutoCAD 2000/LT200 Drawing (dwg) and am getting blue dashed linetype.
Cheers,
--Rob
Inventor 2024.2
